Successfully Integrated Shelly Pro 3EM with HA: Tips & Tricks
Hello fellow HA enthusiasts! :star2: I wanted to share my recent success in integrating the Shelly Pro 3EM into my Home Assistant setup. Initially, I faced some challenges, but I figured it out, and I’m excited to share my experience and tips with you!
The Journey
I’ve been using Shelly devices for a while now, and they’ve been rock solid. However, the Shelly Pro 3EM was a bit tricky at first. I followed the official HA documentation, but the device kept disconnecting. After some research and tweaking, I found a solution that worked for me!
Key Takeaways
Here are some tips that might help if you’re struggling with the Shelly Pro 3EM:
  1. Firmware Update: Ensure your Shelly device is running the latest firmware. I updated mine through the Shelly app and noticed a significant improvement in stability.
  2. Websocket Configuration: I switched from HTTP to Websocket in the Shelly integration settings. This reduced connection issues and made the device more responsive.
  3. Network Stability: Check your network settings. I moved the Shelly to a more stable Wi-Fi channel, which made a huge difference.
  4. Regular Reboots: I set up a weekly reboot for the Shelly using HA’s automation. It’s a simple fix that prevents any long-term issues.
The Payoff
Now, my Shelly Pro 3EM is seamlessly monitoring my electricity usage, and it’s incredibly accurate. It’s been a game-changer for my energy monitoring setup!
A Little Advice
If you’re new to integrating Shelly devices, don’t get discouraged by initial hiccups. Take it step by step, and don’t hesitate to reach out to the community for help. We’re all here to learn and grow together!
Happy automating! :rocket: Let me know if you have any questions or tips to share!
Best regards,
