Hi everyone, I wanted to share my recent success with integrating a smart lock using BLE bonding. I’ve been working on this project for a while, and it’s finally coming together smoothly. Let me walk you through my journey and some tips I picked up along the way.
Initially, I faced some challenges with BLE bonding not being retained after power cycles. This meant that every time the lock rebooted, the mobile app would prompt for pairing again. It was a bit frustrating, but I took it as a learning opportunity.
After some research and experimentation, I discovered that adding specific settings in the configuration file helped retain the bonding information. Here are a few key steps that made a difference:
Configuration Adjustments: I made sure to include
settings_save()andsettings_load()in the appropriate sections of the code. This helped preserve the bonding details across reboots. -
Security Level: I configured the BLE security to level 2, ensuring encrypted communication without the need for a passkey. This was perfect for my setup since the lock doesn’t have an input interface.
Testing Across Devices: I tested the solution on both iOS and Android devices to ensure compatibility. It’s always good to verify across different platforms to catch any potential issues early.
Logs Analysis: Reviewing the logs was crucial. I could see that the bonding information was being stored and loaded correctly after each reboot. This gave me confidence that the solution was solid.
Now, the system works seamlessly. The lock retains the bonding information, and the mobile app doesn’t prompt for pairing after a reboot. It’s a huge relief, and I’m excited to expand this setup further.
If anyone is working on a similar project, I’d be happy to share more details or troubleshoot any issues you might encounter. Happy coding and integrating!
Cheers,
