I’ve always wanted to add remote control for my garage door without breaking the bank, and after some research, I found the perfect solution using a Zigbee Fingerbot. Here’s how I made it work smoothly!
Why Zigbee?
Zigbee was the clear choice for me because it’s low-power and integrates seamlessly with my existing smart home ecosystem. Plus, it avoids the clutter of additional Wi-Fi devices in my house.
Setting It Up
- Hardware Setup: I purchased a Zigbee Fingerbot from AliExpress and a spare remote fob. The setup was straightforward—just install the Tuya Fingerbot driver via Hubitat Package Manager (HPM). It recognized the device right away!
- Integration: Pairing the Fingerbot with my garage door opener was a breeze. I used a spare remote fob to teach the Fingerbot the necessary signals. The driver by @kkossev made this process super smooth.
- Automation: I added a Sonoff contact sensor to monitor the door’s status and a camera for visual checks. Now, I can easily control the garage door from my phone or through voice commands!
Tips for Others
- Make sure your remote fob is compatible with the Fingerbot’s learning capabilities.
- Test the setup thoroughly to ensure all signals are correctly programmed.
- If you’re new to Zigbee, start with a simple project like this to build confidence.
The Satisfaction
Seeing everything work together perfectly was incredibly satisfying. It’s amazing how a little DIY project can add so much convenience to daily life. Plus, knowing that I saved money compared to traditional garage door openers is a huge bonus!
If you’re looking to add garage door control to your smart home, I highly recommend exploring the Zigbee Fingerbot option. It’s affordable, easy to set up, and integrates beautifully with existing systems. Happy automating! ![]()
