Hello fellow smart home enthusiasts! I recently embarked on a journey to integrate my new AICLIV smart light switches with my Homey system, and I thought I’d share my experience in case others are tackling a similar project. This post is a mix of my initial struggles, the solutions I found, and some tips I picked up along the way. Let’s dive in!
The Setup
I purchased these AICLIV WiFi light switches with the intention of controlling my lights through the Homey app. They seemed perfect because they don’t require a hub and are compatible with Alexa, Google Home, and IFTTT. However, my goal was to have them work seamlessly with Homey, which I’ve been using for quite some time now.
The Challenge
When I first tried to set them up, I encountered a bit of a hiccup. The Classic app for SmartThings couldn’t detect the switches, which was a bit frustrating since I was under the impression they were compatible. I downloaded the ‘Smart Life’ app to test things out, and while the switches worked perfectly there, integrating them with Homey wasn’t straightforward.
The Solution
After some research and reaching out to the community, I discovered that while the AICLIV switches aren’t natively supported by Homey, there’s a workaround using the Zigbee2MQTT binding. Here’s how I did it:
- Firmware Update: Ensure your AICLIV switches are running the latest firmware. This can usually be done through the ‘Smart Life’ app.
- Pairing with Zigbee2MQTT: I used a Zigbee USB stick to pair the switches with my Homey. This involved resetting the switch to factory settings and then holding down the reset button until the LED started flashing. I then followed the pairing instructions in the Zigbee2MQTT add-on within Homey.
- Configuration: Once paired, I configured the switches in the Zigbee2MQTT add-on, mapping their states and commands to match how I wanted them to function within Homey.
- Testing: I tested each switch to ensure they were responding correctly to commands from the Homey app.
Tips and Tricks
- Documentation: Keep detailed notes of each step. This helps if you need to troubleshoot later or if you want to replicate the setup for other devices.
- Community Support: Don’t hesitate to ask for help. The smart home community is incredibly supportive, and chances are someone else has faced a similar challenge.
- Patience: Integrating devices from different ecosystems can be tricky. Take your time and don’t rush the process.
The Outcome
After a bit of trial and error, I successfully integrated my AICLIV switches with Homey. It wasn’t as seamless as I initially hoped, but with the right tools and a bit of persistence, it was definitely achievable. Now, I can control my lights through the Homey app, automate them using flows, and even integrate them with my voice assistant of choice.
This experience taught me the importance of thorough research and community engagement when dealing with smart home integrations. While it wasn’t a walk in the park, the satisfaction of getting everything to work perfectly was well worth the effort. If you’re looking to integrate similar devices, I hope this guide helps you avoid some of the pitfalls I encountered.
Happy automating, and feel free to reach out if you have any questions or need advice!
Best regards,
