Hi everyone, I wanted to share my recent experience integrating an Alexa Custom Skill with myopenhab.org using OAuth. It was a challenging but rewarding process, and I hope my insights can help others facing similar hurdles.
Initially, I aimed to create a skill that goes beyond the standard Home Skills, offering rich interactions with all my openHAB items. However, setting up OAuth was a significant barrier. After extensive research and trial and error, I discovered that the key was understanding the OAuth flow specifics for myopenhab.org. I realized that out-of-band registration wasn’t required, but precise configuration was crucial.
One of the most frustrating parts was ensuring that my skill was authorized correctly. I had to meticulously check each setting, from client IDs to redirect URIs, to ensure they matched myopenhab.org’s requirements. It was a meticulous process, but once everything aligned, the integration worked seamlessly.
I also found that leveraging existing documentation and community forums was invaluable. While there wasn’t specific guidance for my exact setup, piecing together information from various sources helped me craft a solution. I recommend others to approach the problem methodically, verifying each step, and not hesitate to reach out to the community for support.
In the end, seeing my skill interact with openHAB was incredibly satisfying. It not only fulfilled my project’s goals but also deepened my understanding of OAuth and Alexa skill development. I’m excited to continue refining this integration and explore further possibilities with my smart home setup.
Cheers to all the tinkerers out there—keep experimenting and innovating!
