I recently embarked on a project to automate my home’s curtains and lighting system, and I’m thrilled to share my journey and tips with you! ![]()
After researching various options, I decided to use MQTT to connect my ESPHome devices with Home Assistant. The goal was to create a seamless experience where my curtains open and close automatically based on sunrise and sunset times, while the lights adjust accordingly to create a cozy ambiance.
Challenges and Solutions
MQTT Configuration: Initially, I struggled with setting up the MQTT topics correctly. I found that using templates in Home Assistant helped bridge the gap between my ESPHome devices and the automation logic. For example, I used a template sensor to calculate the desired brightness based on the time of day.
Device Integration: Integrating my WyzeCam Pan v3 into the system was a breeze once I configured the MQTT topics properly. It now acts as a motion detector, adjusting the lighting and curtains dynamically when movement is detected.
Firmware Updates: I encountered ahiccup when updating my ESPHome devices. A simple factory reset and reconfiguration solved the issue, and now everything runs smoothly!
Setup Highlights
- Smart Curtains: Using a Zooz ZEN73 relay, I automated my curtains to open at sunrise and close at sunset. This not only saves energy but also enhances the natural light flow in my home.
- Dynamic Lighting: My lights now adjust their brightness based on the time of day, thanks to a combination of time_date sensors and template switches in Home Assistant.
Tips for Others
- Start Small: Begin with a single device or feature to get comfortable with the system before scaling up.
- Leverage Templates: Templates in Home Assistant are incredibly powerful for creating custom logic without diving deep into coding.
- Regular Firmware Updates: Keep your devices updated to ensure optimal performance and security.
This project has been incredibly rewarding. Not only has it made my home more efficient, but it’s also added a touch of luxury to my daily life. The satisfaction of seeing everything work seamlessly is unparalleled! ![]()
If anyone has questions or needs help with similar projects, feel free to reach out. I’d be happy to share more details or troubleshoot issues together! ![]()
