I’ve been on a journey to integrate my cFos Power Brain Wallbox into my smart home ecosystem, and I’m thrilled to share my experience! ![]()
The Challenge:
Initially, I was a bit overwhelmed by the JSON data structure returned by the Wallbox. I knew I needed to extract specific values like power consumption and total energy, but I wasn’t sure how to map them correctly in my setup.
The Solution:
After some research and experimentation, I discovered that using the cfos.things and cfos.items configurations was the key. Here’s a quick breakdown of what worked for me:
markdown
- cfos.things: Defined the channels to pull data from the Wallbox.
- cfos.items: Mapped these channels to items for easy access in my dashboard.
The Outcome:
Now, I can monitor my energy usage in real-time, set up rules based on power consumption, and even track my total energy over time. It’s incredibly satisfying to see everything working seamlessly together!
Tips for Others:
- Start Small: Begin by pulling one data point at a time to ensure your configuration is correct before adding more.
- Leverage Documentation: The cFos eMobility HTTP API documentation was invaluable in understanding the structure of the JSON response.
- Community Support: Don’t hesitate to reach out to forums or communities if you get stuck. The smart home community is incredibly supportive!
If you’re looking to integrate your cFos Power Brain Wallbox, I hope this helps you get started. Let me know if you have any questions or tips to share! ![]()
