Hey everyone!
I wanted to share my recent experience integrating Devolo Home Control with Home Assistant. It’s been a journey, but I’m thrilled to say it’s working perfectly now! ![]()
My Setup
I’ve been using Devolo Home Control for a while now, and I recently decided to bring it into my Home Assistant ecosystem. My configuration includes:
- Home Assistant Version: core-2022.2.2
- Installation Type: Container on Synology DS218+
- Devolo Devices: A mix of smart plugs and sensors
The Process
Getting Started:
I started by heading to the Integrations section in Home Assistant. Searching for Devolo Home Control was straightforward. The setup asked for my email, password, and the My Devolo URL (which was already filled in ashttps://www.mydevolo.com). -
Initial Challenges:
After entering my credentials, I encountered an error:Error during setup - check the protocols. This was a bit discouraging, but I knew it was just a matter of troubleshooting. -
Digging Deeper:
I checked the logs and found aKeyError: 'default_hz'. After some quick research, I realized this might be related to the firmware version on my Devolo devices. I ensured all my devices were up to date through the Devolo app. -
The Fix:
It turned out the issue was with the Home Assistant integration itself. Updating to the latest version of Home Assistant resolved the problem. Once updated, the integration went through without a hitch! -
Final Setup:
Now, all my Devolo devices are neatly integrated into Home Assistant. I can control my smart plugs, monitor my sensors, and even create automations based on Devolo inputs. It’s been a game-changer for my smart home setup!
Tips for Others
- Check Firmware: Ensure all Devolo devices are running the latest firmware.
- Update Home Assistant: Always use the latest version of Home Assistant for the best compatibility.
- Logs Are Your Friend: If something goes wrong, the logs will give you crucial clues to troubleshoot.
Integrating Devolo Home Control with Home Assistant was a bit of a challenge, but the payoff is worth it. My home is now more connected and easier to manage than ever before. If you’re considering this integration, don’t hesitate—just be prepared to troubleshoot if needed! ![]()
Happy automating! ![]()
