I’ve recently embarked on a journey to integrate ESPHome with my smart lighting setup, and I must say, it’s been an incredibly rewarding experience! ![]()
Starting with the basics, I wanted to automate my living room lights to turn on and off based on my presence. After some research, I decided to use ESPHome for its flexibility and ease of integration with Home Assistant. Here’s a quick rundown of my setup:
Hardware Setup: I installed ESPHome on a Raspberry Pi and connected it to my smart bulbs via a Zigbee gateway. This allowed me to control the bulbs directly from Home Assistant without any additional hubs.
Configuration: I set up a YAML file to define my lights and their respective automation rules. For instance, I programmed the lights to dim when I leave the room and brighten as I approach. It took a bit of tweaking, but the results were worth it!
Automation Success: The best part? The system now seamlessly integrates with my existing smart home ecosystem. I can control everything from my phone or even through voice commands using Alexa.
Here’s a snippet of my configuration for reference:
yaml
light:
- platform: zigbee
name: “Living Room Lights”
brightness: true
color_temp: true
effect: true
automation:
- alias: “Dim Lights on Leave”
trigger:- platform: state
entity_id: binary_sensor.living_room_occupancy
to: ‘off’
action: - service: light.turn_off
entity_id: light.living_room_lights
- platform: state
Tips for Others: If you’re looking to dive into ESPHome, start with a simple project and gradually build up. Make sure to back up your configurations regularly and don’t hesitate to explore the extensive community resources available. It’s a fantastic way to customize your smart home exactly how you want it!
Happy tinkering! ![]()
