Successfully Integrating Ferroli Omnia Heat Pump into Home Assistant
Hi everyone, I wanted to share my recent success in integrating my new Ferroli Omnia M 3.2 heat pump into Home Assistant. This was a bit of a challenge, but I managed to work through it, and I thought it would be helpful to document my experience for anyone else who might be facing a similar situation.
When my new heat pump arrived, I was excited to get it up and running. The unit comes with its own Wi-Fi module and a dedicated app, but I was determined to integrate it into my existing Home Assistant setup. Unfortunately, I couldn’t find any straightforward options for HVAC integration within Home Assistant, which was a bit of a setback. I had previously used my old Nefit Easy Thermostat without issues, so I was hoping for a similar experience.
After some research and reaching out to the community, I discovered that while there isn’t a built-in integration for the Ferroli Omnia, there are some workarounds. I decided to use the MQTT protocol to bridge the communication between the heat pump’s app and Home Assistant. This involved setting up a custom MQTT broker and configuring the heat pump’s app to publish and subscribe to specific topics. It was a bit technical, but with some trial and error, I got it working.
Once the integration was complete, I could control my heat pump directly from Home Assistant, which was a huge relief. I even set up some automations to adjust the temperature based on the time of day and outdoor weather conditions. This has made my home much more comfortable and energy-efficient.
I wanted to share this success story to inspire others who might be struggling with similar integrations. If you’re hesitant to dive into custom setups, I encourage you to give it a try. The sense of accomplishment when everything clicks into place is well worth the effort.
For those interested in the nitty-gritty details, I’ve documented my entire process in a GitHub repository. Feel free to reach out if you have any questions or need guidance. Happy automating!
Hi there, any chance that you could share your git repo and findings?
