Successfully Integrating Fibaro Door Window Sensor 2 with SmartThings Hub
Hello everyone, I wanted to share my experience with integrating the Fibaro Door Window Sensor 2 with the Samsung SmartThings Hub. While the process had its challenges, I managed to get everything working smoothly, and I thought it might be helpful to document my journey for others who are just starting out with smart home automation.
Initially, I was thrilled to set up the Fibaro sensor as it promised to offer temperature monitoring alongside its primary function of detecting door and window states. The sensor was easily added to the SmartThings app, and at first glance, everything seemed to be working perfectly—showing the correct open/close state, temperature readings, and even battery life. I decided to take it a step further by setting up an automation that would turn on the lights in the room whenever the door was opened. This is where things started to go south.
After setting up the automation, the sensor began to display an open state continuously, regardless of the actual door position. I retried the setup multiple times, deleting and re-adding the device, but the issue persisted. The battery level also started showing inconsistencies, jumping from 80% to 100% without any logical explanation. I couldn’t help but feel a bit discouraged, especially since I’m still new to this world of smart home technology.
Determined to resolve the issue, I began researching online and found that others had experienced similar problems with the Fibaro sensor. It turned out that the sensor requires a specific type of Zigbee protocol, and not all devices on the network play nicely together. After some trial and error, I discovered that resetting the sensor to its default factory settings and carefully following the pairing process in the SmartThings app was the key to getting everything back on track.
Once the sensor was properly paired, the automation began working as intended. The lights turn on when the door opens, and the sensor now accurately reflects the door’s state. I even went a step further by integrating the temperature readings into my home’s environmental monitoring system, which has been a fantastic addition.
This experience taught me the importance of patience and thorough research when dealing with smart home devices. It also highlighted the value of community support—without the insights shared by others who had faced similar challenges, I might still be struggling with this issue. I’m now more confident in tackling future projects and can’t wait to see how my smart home setup continues to evolve.
If anyone else is having trouble with their Fibaro sensors or any other devices, don’t hesitate to reach out. I’m happy to share what I’ve learned and help troubleshoot any issues you might encounter. Happy automating everyone!
