Successfully Integrating Fröling Lambdatronic S3100 into Home Assistant
I recently faced a challenge integrating my Fröling Lambdatronic S3100 boiler into Home Assistant, but through persistence and some clever scripting, I managed to pull it off. Here’s my journey and how you can replicate it!
The Challenge
My boiler, a Fröling Lambdatronic S3100, didn’t have a direct integration with Home Assistant. After some research, I stumbled upon a GitHub project called ‘radiator’ by Daniel Höpfl. This project allows reading data from the boiler via RS232, which was exactly what I needed. However, setting it up wasn’t straightforward, especially since I’m relatively new to this.
The Solution
  1. Hardware Setup: I started by connecting an RS232/USB adapter to the boiler’s maintenance port and my Raspberry Pi. This required a bit of trial and error with the wiring, but once connected, the adapter’s TX/RX LEDs blinked, indicating data transfer—a reassuring sign!
  2. Installing radiator: Next, I downloaded and installed the ‘radiator’ project on my Raspberry Pi. Running it with the command ./configure, make, and make install set everything up. Testing it with radiator -D4 T 2 /dev/ttyUSB0 confirmed it was working.
  3. MQTT and Node-RED Integration: To bridge the data into Home Assistant, I installed Mosquitto and Node-RED. I created a Node-RED flow that periodically runs the radiator command, converts the output into JSON, and publishes it to MQTT. This way, Home Assistant could receive real-time updates from the boiler.
  4. Configuring Home Assistant: Finally, I added each sensor manually in Home Assistant, specifying the MQTT topics and value templates to extract the correct data from the JSON payload. It was meticulous, but seeing the boiler’s data appear in my dashboard was incredibly satisfying!
Tips for Success
  • Scripting: Writing a script to parse the radiator output was crucial. It transformed raw data into a structured JSON format, making it easier to integrate with Home Assistant.
  • Testing: Regularly test each component—radiator, MQTT, Node-RED—to ensure they’re working before moving on. This saved me hours of troubleshooting.
  • Community Support: Don’t hesitate to reach out to communities like GitHub or forums. Daniel Höpfl was incredibly helpful when I encountered issues.
Conclusion
Integrating legacy systems like my boiler into modern smart home setups can be daunting, but with the right tools and a bit of creativity, it’s entirely achievable. This project not only enhanced my home automation setup but also deepened my understanding of scripting and data integration. If you’re looking to integrate similar systems, I highly recommend exploring the ‘radiator’ project and leveraging MQTT for seamless communication.
Happy automating!
