After spending several days trying to integrate HACS into my Home Assistant setup, I finally got it working! Here’s what I learned along the way. ![]()
The Challenge with HACS
I installed Home Assistant using Docker on my Raspberry Pi 4 and wanted to add HACS for custom integrations. I followed the guide, but kept running into issues with the GitHub Token. After a few attempts, I noticed HACS wouldn’t load properly. I checked the dashboard and saw the error message about pending updates. It was frustrating because I couldn’t figure out what was wrong. I tried clearing the token and re-entering it, but nothing worked. Finally, I found a corrupted line in the hacs.repositories file and fixed it. After rebooting, HACS started working, but now I have to keep an eye on that file to prevent future issues. ![]()
SSH Connection Problems
Another hurdle I faced was setting up SSH access to my Home Assistant instance. I enabled the Terminal & SSH addon and generated an ed25519 key on my computer. I added port 22 and tried connecting, but kept getting a permission denied error. It worked when I used a password, but I wanted key-based authentication. I checked my SSH logs and realized the known_hosts file was missing. I regenerated it using ssh-keygen -F [IP_ADDRESS] and added the correct permissions to my key. Now, I can connect seamlessly without a password! ![]()
What I Learned
- Always double-check your configuration files for errors.
- SSH issues often boil down to file permissions or missing keys.
- Don’t hesitate to reach out to the community for help—someone has probably faced the same problem!
If anyone else is struggling with HACS or SSH, feel free to ask. I’m happy to share what I’ve learned! ![]()
