Successfully Integrating HASmartThermostat with Homematic IP
I’ve been on a journey to integrate my HASmartThermostat with Homematic IP thermostats and a Zigbee outlet in Home Assistant. It’s been a bit of a challenge, but I’m thrilled to share my success story and some tips I’ve picked up along the way! :tada:
The Setup
I wanted to use my Homematic IP thermostats to provide both set and actual temperature readings for the HASmartThermostat integration. The goal was to control a Zigbee outlet for heating. Initially, I faced some hurdles with the configuration, but after some research and tweaking, everything started to fall into place.
Key Learnings
  1. Configuration Adjustments: I discovered that adjusting the kp, ki, and kd values was crucial for stable temperature control. I ended up using kp: 50, ki: 0.01, and kd: 2000 for optimal performance.
  2. Keep Alive Feature: Enabling the keep_alive feature with a 60-second interval helped maintain a consistent connection between the thermostat and the outlet.
  3. Away Mode: Setting the away_temp to 14°C proved to be a great energy-saving tip, especially when I’m not at home.
The Outcome
After some trial and error, my setup now works seamlessly! The HASmartThermostat reads temperature values from the Homematic IP thermostats and controls the Zigbee outlet perfectly. It’s amazing how integrating different systems can create such a smooth and efficient heating solution.
Tips for Others
  • Start Simple: Begin with a basic configuration and gradually add features like away mode or keep alive once the core functionality is working.
  • Monitor Logs: Keep an eye on your Home Assistant logs for any errors or warnings that might give you clues about what’s not working.
  • Community Support: Don’t hesitate to reach out to the community if you’re stuck. forums like this one are goldmines of knowledge!
Integrating different smart home devices can be a bit overwhelming at first, but with patience and a bit of experimentation, it’s incredibly rewarding. I’m now enjoying a perfectly heated home with minimal effort, and I couldn’t be happier! :sun_with_face:
If anyone has questions or needs help with their own integrations, feel free to ask. I’d be happy to share more details or troubleshoot together! :wave:
