Recently, I decided to dive into the world of home automation and set up Home Assistant on my Apple Silicon Mac. The process was smoother than I expected, thanks to the new AArch64 image mentioned in the Home Assistant OS 8 release notes. Here’s how I made it happen:
Download & Install UTM: I started by downloading UTM from the official website. It’s a fantastic tool for running virtual machines, and the setup was straightforward.
Download the Home Assistant OS AArch64 Image: Next, I downloaded the .qcow2 image from the official GitHub repository. This was crucial for ensuring compatibility with my Apple Silicon Mac.
Create the Virtual Machine: Using UTM, I created a new VM and imported the qcow2 image. I configured the network settings to use bridged mode, which was essential for internet access.
Resize the Virtual Disk: After installation, I noticed the VM’s disk size was quite small. Following some community guides, I resized it to 32GB, which provided ample space for my setup.
The result? A seamless integration of Home Assistant into my smart home ecosystem. I now enjoy a beautifully designed dashboard, thanks to the Dynamic Material Design 3 theme, which adapts effortlessly to both light and dark modes. Each room’s temperature is color-coded, creating an intuitive heatmap effect that’s both functional and visually appealing.
I’m thrilled with how everything came together. The community support was invaluable, and I’m excited to explore even more possibilities with Home Assistant. If you’re considering setting this up, I highly recommend giving it a try—it’s a game-changer for home automation enthusiasts!
