Successfully Integrating Home Connect Devices with Home Assistant
Hey everyone, I wanted to share my recent success in integrating my Home Connect devices with Home Assistant. It’s been a journey, but I’m thrilled to have everything working seamlessly now!
The Challenge
I’ve been using Home Assistant for a while now, and I recently decided to add some smart home appliances to my setup. My dishwasher and washing machine are both Home Connect-enabled, so I thought it’d be a breeze to connect them. However, the setup wasn’t as straightforward as I hoped.
Initially, I followed the standard steps: verifying my appliances were online, creating a Home Connect account, and setting up OAuth2 in Home Assistant. But when it came to linking my account, I kept running into errors. The error messages were vague, and I couldn’t figure out why the link wasn’t working. I tried different URLs, checked my credentials repeatedly, and even restarted my router, but nothing seemed to help.
The Solution
After some research and reaching out to the community, I found that the issue was with the redirect URL. I had set it to the default homeassistant.local:8123, but it turns out that Home Connect requires a specific format. I changed the redirect URL to https://my.home-assistant.io/redirect/oauth and retried the linking process. This time, it worked perfectly!
Tips for Others
If you’re trying to integrate Home Connect devices, here are a few tips:
  • Double-check your redirect URL. It needs to match exactly what Home Assistant expects.
  • Ensure your Home Connect account is properly registered and that your appliances are listed as online.
  • If you encounter errors, try clearing your Home Assistant OAuth2 tokens and starting fresh.
The Outcome
Now, I can monitor and control my appliances directly from Home Assistant. It’s incredibly convenient to start a wash cycle from my phone or check the remaining time on my dishwasher. This integration has taken my smart home setup to the next level!
If anyone else is struggling with Home Connect integration, feel free to reach out. I’d be happy to help troubleshoot or share what I’ve learned. Happy automating! :rocket:
