Hey everyone, I wanted to share my recent success in integrating HomeAssistant data with an ESPHome display. It was a bit of a journey, but I managed to get everything working smoothly!
Initially, I was trying to display sensor data from HomeAssistant directly on my ESPHome TFT display. While I could pull data from MQTT topics using ESPHome’s MQTT Subscribe platform, integrating data directly from HomeAssistant was causing some issues. The ESP would crash during startup, which was quite frustrating.
After some research and troubleshooting, I realized the problem was related to how the ESP was handling the MQTT connections. I adjusted the configuration to ensure that the ESP only subscribed to necessary topics and optimized the data parsing. This helped stabilize the connection and prevent crashes.
Here’s a quick tip for anyone facing similar issues: Always check your MQTT broker logs to ensure that the ESP is successfully connecting and subscribing to the right topics. Also, consider using a more efficient data format or reducing the frequency of updates if you’re dealing with a lot of sensors.
Now, my display shows both local MQTT sensor data and HomeAssistant sensor data without any issues. It’s been a great way to centralize all my smart home information in one place!
If anyone has questions or needs help with similar setups, feel free to reach out. I’d be happy to share more details or troubleshoot together!
Cheers,
