After spending weeks researching and planning, I finally completed my custom home alarm system using HomeMatic components. The journey was filled with challenges, but the result exceeded my expectations! Here’s how I pulled it all together.First, I wanted a system that could be fully integrated into my existing HomeMatic setup without relying on additional hardware from other manufacturers. The key was finding the right combination of components that could work seamlessly together. I ended up using a 6-way wall switch as a keypad for code entry, which was a clever solution since it matched my aesthetic preferences.The system’s logic revolves around a few core variables: presence, alarm status, and code input validation. These variables were crucial in ensuring that the alarm could transition smoothly between armed and disarmed states. I also implemented a prearming feature, which allows the system to be armed even if certain doors are still open, providing flexibility without compromising security.One of the most rewarding parts was reverse-engineering the Lonhand Protocol for the USR-R16-T relay module. It was a puzzle, but successfully controlling each channel individually was a huge milestone. I documented the process and shared the Python script with the community, hoping it can help others facing similar challenges.For the alarm’s audio output, I utilized my existing smoke detectors. By connecting them to a 4-channel actor, I created a reliable and scalable solution. The system now sends a 2-second signal to trigger the alarms, and a 7-second signal to deactivate them, ensuring they’re always ready when needed.The testing phase was intense, but it paid off. I simulated various scenarios, from manual disarm during motion detection to full alarm activation. The system proved to be both reliable and efficient, giving me peace of mind.If you’re considering a similar project, my advice is to start small, test each component thoroughly, and document everything. It’s a rewarding experience that enhances your home’s security and automation capabilities.Thank you to everyone in the community who shared their knowledge and experiences. Your contributions made this project possible! ![]()
