I recently installed the Ikea Fyrtur blinds without the gateway and managed to integrate them with Home Assistant using the Conbee 2 key. It was a bit of a learning curve, but the result is fantastic! Here’s my experience and some tips for those looking to do the same.
1. Manual Control Compatibility
One of my main concerns was whether integrating the blinds with HA would interfere with manual operation using the remote button. After some testing, I’m happy to report that both methods work perfectly together. You can still use the remote to adjust the blinds manually, while HA allows for seamless automation.
2. Pairing the Remote and Repeater
I also wanted to pair the remote button and the repeater within HA to enhance functionality. This wasn’t immediately obvious, but after some research and experimentation, I found that pairing them ensures better reliability, especially in larger spaces or areas with multiple obstructions.
3. Setting Up Automation Scripts
Creating scripts to automate opening and closing the blinds was a breeze. Using HA’s built-in automation tools, I set up schedules based on sunrise and sunset times. This has been a game-changer for creating a more comfortable living environment without manual intervention.
Tips for Others
- Start Simple: Begin with basic automation before diving into complex scripts.
- Check Documentation: The official HA documentation and community forums are invaluable resources.
- Experiment Safely: Don’t hesitate to test different configurations in a controlled environment.
I’m thrilled with how this integration has improved my smart home setup. It’s a great example of how affordable and flexible Ikea products can work beautifully with more advanced systems like Home Assistant. Happy automating everyone! ![]()
