Successfully Integrating Ikea Tradfri Bulbs with Home Assistant
I wanted to share my success in connecting Ikea Tradfri light bulbs to Home Assistant using a Sonoff ZBDongle-P. After some research and troubleshooting, I managed to get everything working smoothly. Here’s how I did it:
  1. Hardware Setup: I connected the Sonoff ZBDongle-P to my Raspberry Pi 4 via a USB extension cable. This ensured a stable connection between the Zigbee dongle and my Home Assistant setup.
  2. Firmware Update: The key to making this work was updating the Sonoff ZBDongle-P’s firmware. I used a GitHub repository that provided a script to flash the latest Z-Stack firmware onto the device. This involved installing Python packages and running a script to update the firmware to version 20240710.
  3. Pairing the Bulbs: Once the firmware was updated, I entered the pairing mode on the Ikea Tradfri bulb by cycling the power 6 times while keeping it off for a few seconds. This allowed the bulb to connect to the Sonoff ZBDongle-P.
  4. Testing and Automation: After pairing, I tested the bulbs through Home Assistant and set up some simple automations. For example, I created a script to turn the lights off and then on at full brightness with a specific color temperature. This ensures a consistent and pleasant lighting experience.
  5. Tips for Others: If you’re considering this setup, make sure to update the firmware on your Sonoff ZBDongle-P. Also, keep the bulb off for a bit longer during pairing to ensure a stable connection.
This integration has been a game-changer for my smart home setup, and I’m thrilled with how seamless it turned out to be. If anyone has questions or needs help with a similar project, feel free to reach out!
Cheers,
