Hey everyone,
I wanted to share my recent success in integrating an infrared (IR) remote control system with OpenHab. This has been a journey of trial and error, but I’m thrilled to finally have a seamless setup that allows me to control my fan and lights through my smart home system.
The Challenge
My fan comes with an IR remote, and while it works perfectly manually, integrating it into my smart home setup was a puzzle. I tried using a generic Wi-Fi IR bridge with Tasmota for MQTT control, but the initial setup was frustrating. The main issue was the complexity of sending JSON commands through MQTT, which required careful handling of quotes and commas.
The Solution
After some research and experimentation, I found a method that works beautifully within OpenHab’s MainUI. Here’s a simplified version of what I did:
Adding a String Item
- I created a string item named
ir_study_stringto handle the commands sent from my UI buttons.
Setting Up Buttons on My Page
- Using OpenHab’s UI editor, I added buttons for each function (fan on/off, fan speed, light on/off, etc.). Each button sends a specific command to
ir_study_string.
Installing JavaScript for Enhanced Functionality
- I installed the JavaScript Scripting add-on to leverage ECMAScript 2021. This allowed me to write a rule that interprets the command from
ir_study_stringand sends the appropriate JSON payload to my IR bridge.
Creating the Rule
- The rule checks the command received by
ir_study_stringand sends the corresponding JSON command to the IR bridge. For example, pressing the fan on/off button sends the specific IR code to toggle the fan.
The Outcome
This setup has transformed how I interact with my fan and lights. Instead of fumbling with the remote, I can now control everything seamlessly through my OpenHab interface. It’s incredibly satisfying to see all the pieces come together!
Tips for Others
- Keep It Simple: Don’t overcomplicate your setup. Start with basic commands and gradually add more features as you become comfortable.
- Leverage OpenHab’s UI: Using labels and lists makes it easy to manage your controls without diving into code.
- JavaScript is Your Friend: The JavaScript add-on opens up a world of possibilities for handling complex commands and automations.
I hope this guide helps someone else looking to integrate IR control into their smart home setup. It’s a bit of a learning curve, but the payoff is well worth it!
Happy automating! ![]()
