Hey everyone, I wanted to share a success story that might be helpful for others looking to integrate KNX and Z-Wave systems. I recently faced a challenge with dimming a Z-Wave device using KNX, but after some troubleshooting, I managed to get it working smoothly. Here’s how it went:
I replaced my old KNX dimmer with a Z-Wave device, specifically a Zipato RGBW bulb. Initially, I set up a simple rule to pass ON/OFF commands from KNX to Z-Wave, and that worked perfectly. However, when I tried dimming, I encountered some errors in the logs. The issue was that the dimming commands from KNX weren’t being interpreted correctly by the Z-Wave bulb.
After some research, I realized that I needed to convert the KNX dimming commands into a format that the Z-Wave bulb could understand. I ended up modifying my rule to handle the dimming values as percentages. This involved capturing the KNX commands, converting them into a compatible format, and then sending them to the Z-Wave bulb. It took a bit of trial and error, but eventually, everything started working as intended!
Here’s a snippet of the adjusted rule I used:
plaintext
rule “KNX to Z-Wave Dimming Adjustment”
when
Item KNX_Dimmer changed
then
val String knxValue = KNX_Dimmer.state.toString
val Integer zWaveValue = knxValue.toFloat * 100
sendCommand(ZWave_Device, zWaveValue)
end
This adjustment ensured that the dimming commands were correctly interpreted by the Z-Wave bulb. I also started logging the KNX commands to better understand their structure, which was crucial for making the necessary conversions.
It’s amazing how a little bit of scripting can bridge the gap between different smart home ecosystems. If anyone else is working on a similar integration, I’d be happy to share more details or help troubleshoot issues. Let me know if you have any questions or if you’ve found other effective solutions!
Happy automating! ![]()
