Successfully Integrating Lumary Wifi RGBWW Recessed Lights with Hubitat
Recently, I decided to upgrade my home lighting setup by replacing my existing Sylvania Smart+ RGBWW recessed lights with the Lumary Wifi RGBWW recessed lights. After doing some research, I was excited to find that these lights are not only brighter (1100 lumens) but also compatible with my Hubitat Elevation platform. Here’s how I made it work!
Setup Process
  1. Unboxing & Installation: The installation was straightforward. The lights come with a retrofit design, making them easy to install without any major rewiring. I simply removed the old fixtures and slid the new Lumary lights in place.
  2. Connecting to Hubitat: Since these lights use WiFi, I didn’t need any additional hubs or bridges. I followed the instructions in the Hubitat app to add the devices. The process was seamless, and they were recognized almost immediately.
  3. Testing & Customization: Once connected, I tested the brightness and color settings. I was impressed by the smooth dimming and vibrant color transitions. I also set up some simple automations using Hubitat’s Rule Machine, such as turning the lights off after 30 minutes of inactivity.
Why I Chose Lumary
  • Brightness: The 1100 lumens provide a much brighter light compared to my previous setup, which was perfect for my living room.
  • Compatibility: Being WiFi-based was a big plus since I didn’t want to deal with Zigbee or Z-Wave integration issues.
  • Aesthetics: The sleek design blends seamlessly with my home decor.
Tips for Others
If you’re considering these lights, here are a few tips:
  • Check Placement: Ensure the lights have a clear line of sight to your router for optimal performance.
  • Start Simple: Begin with basic automations and gradually add more complex routines as you get comfortable.
  • Experiment: Don’t hesitate to try different color combinations and brightness levels to find what works best for your space.
Conclusion
Upgrading my lighting system to the Lumary Wifi RGBWW recessed lights has been a fantastic experience. They integrate effortlessly with my Hubitat setup, offer excellent brightness and color quality, and have added a whole new level of convenience and ambiance to my home. If you’re looking to enhance your lighting system, I highly recommend giving these a try!
Happy lighting! :star2:
