Successfully Integrating Magic Home Pro with SmartThings via IFTTT
Hey everyone, I wanted to share a really cool workaround I found for integrating Magic Home Pro RGBW LED strip controllers with SmartThings without having to reflash the device or spend extra money on adapters. I stumbled upon this solution while researching ways to control my LED strips through SmartThings, and it turned out to be a game-changer!
Here’s what I did: I discovered that by using IFTTT’s Magic Hue applet, I could create a virtual switch in SmartThings and link it to my Magic Home Pro devices. The process was surprisingly straightforward:
  1. Create a Virtual Switch: I set up a virtual switch in SmartThings, which acts as the control point for my LED strips.
  2. Set Up IFTTT Applet: I created a simple IFTTT applet that triggers Magic Hue actions whenever the virtual switch is toggled in SmartThings.
  3. Assign Commands: Each state of the switch (on, off, color changes) corresponds to specific commands sent to my Magic Home Pro controller via the Magic Hue applet.
The best part is that this method works seamlessly without any additional hardware or complex setup. It’s perfect for anyone looking to integrate their Magic Home Pro devices into their SmartThings ecosystem without the hassle of reflashing or purchasing extra adapters.
I’ve been using this setup for a few weeks now, and it’s been rock solid. My LED strips respond instantly to commands from SmartThings, and I can even control them through Alexa routines. It’s such a neat solution that I thought I’d share it with the community in case others are looking for a similar workaround.
If anyone has questions or needs help setting this up, feel free to reach out! I’d be happy to walk you through the steps in more detail.
