Successfully Integrating Monoprice Blackbird 4x4 Video Matrix with Home Assistant
Hey everyone, I wanted to share my experience integrating the Monoprice Blackbird 4x4 video matrix into Home Assistant. This was a bit of a challenge, but I managed to get it working smoothly!
Setup and Configuration
I started by connecting the Blackbird matrix to my Raspberry Pi using a USB-to-RS232 converter. The device requires specific serial settings: 115200 baud rate, 8 data bits, no parity, and 1 stop bit. I configured these settings in the configuration.yaml file under the serial platform.
Automation and Control
To control the matrix, I created shell commands for each input-output combination. For example, pressing a button in Lovelace sends a specific HEX command to the matrix, switching the input accordingly. I also set up power control for the matrix, allowing me to turn it on or off directly from Home Assistant.
Challenges and Solutions
One issue I encountered was the matrix not responding consistently after initial setup. I found that rebooting the USB-to-RS232 converter often resolved this. Additionally, extracting status feedback from the matrix was complex, so I focused on the functionality I needed most—input switching—and left status readback for future improvements.
Tips for Others
If you’re planning to integrate a similar device, here are my tips:
  • Double-check all serial settings and ensure your converter is reliable.
  • Test each command individually before setting up automation.
  • Don’t hesitate to reach out to the community for help; forums and Discord have been invaluable resources for me.
This integration has significantly enhanced my home theater setup, and I’m thrilled with the result. If anyone has questions or needs assistance, feel free to ask—I’m happy to help!
Cheers,
