Hello everyone, I’m thrilled to share my recent success in integrating MQTT switches into my smart home setup. After some initial hurdles, I managed to get everything working smoothly, and I’d love to walk you through my journey and share some tips along the way.
The Challenge:
I recently set up my Sonoff devices with Tasmoto firmware, aiming to control them via MQTT. Everything seemed to work perfectly when turning the switches on, but I noticed a peculiar issue—when I toggled the switch off in openHAB, the ‘OFF’ command wasn’t being sent to the MQTT topic. This was puzzling, as the ‘ON’ command worked without any issues.
The Solution:
After some research and trial and error, I discovered that adjusting the custom-on-value setting to ‘OFF’ resolved the problem. It turns out the switch only sends the MQTT command when the item switch is turned on by default. By inverting the switch, the ‘OFF’ command was correctly transmitted. This was a simple yet effective fix that restored full functionality to my setup.
Sharing My Experience:
I wanted to document my experience in case others encounter similar issues. Here’s a quick rundown of the steps I took:
- Configuration Check: I reviewed the MQTT configuration settings in openHAB, ensuring that the command and state topics were correctly specified.
- Testing Commands: Using MQTT Explorer, I manually sent ‘ON’ and ‘OFF’ commands to observe the behavior and confirm where the disconnect was occurring.
- Adjusting Settings: I modified the custom-on-value to ‘OFF’ in the channel configuration, which effectively inverted the switch behavior.
- Verification: After making the change, I tested the switch extensively to ensure both ‘ON’ and ‘OFF’ commands were being sent correctly.
Tips for Others:
- Logging is Your Friend: OpenHAB’s logs provided invaluable insights into why the ‘OFF’ command wasn’t being sent. Always check the logs first when troubleshooting.
- Community Resources: Don’t hesitate to consult forums and community resources. Someone else might have encountered the same issue and documented their solution.
- Incremental Testing: When making changes, test each component incrementally. This helps isolate the problem and prevents cascading issues.
Looking Ahead:
Now that my MQTT switches are fully functional, I’m excited to expand my smart home setup. I’m considering integrating more devices and exploring advanced automation scenarios. If anyone has tips on optimizing MQTT performance or suggestions for other devices to integrate, I’d love to hear them!
Thank you for reading, and happy automating! ![]()
