I’ve been on a journey to consolidate my smart home ecosystem, and I’m thrilled to share my experience with integrating multiple brands into Hubitat. For years, I relied on SmartThings, but the limitations became increasingly frustrating, especially with the lack of support for certain devices and the occasional hiccups in functionality. After doing some research, I decided to make the switch to Hubitat, and I couldn’t be happier with the results.### My SetupI live in a large property with a detached garage, so range has always been a concern. I have one Hubitat hub in the house and another in the garage, both connected via my home network. The best part? They communicate seamlessly! I can control my garage door from inside the house, and my outdoor lights respond to commands from my smart switches. It’s like having a single, cohesive system spread across my entire property.### Moving Devices OverTransitioning from SmartThings to Hubitat was a bit daunting at first, especially with 86 Z-Wave devices. I was worried about the process being time-consuming, but Hubitat’s integration made it surprisingly smooth. While I did have to manually move each device, the Hubitat app made it straightforward. I simply added each device one by one, and they paired up without any issues. The same went for my rules and automations—I recreated them in Hubitat, and they work even better than before!### Favorite FeaturesOne feature that stands out is the ability to create complex automations without any lag. My garage door now opens automatically when I pull into the driveway, thanks to a combination of motion sensors and the Hubitat hub. It’s these little conveniences that make living in a smart home truly enjoyable.### Tips for OthersIf you’re considering making the switch, here are a few tips:- Plan Ahead: Take inventory of all your devices and their current configurations.- Backup Your Rules: Before you start moving things over, make sure you have a backup of your automations.- Take It Step by Step: Don’t try to move everything at once. Start with your most critical devices and gradually integrate the rest.### Final ThoughtsThe switch to Hubitat has been a game-changer for me. The system is reliable, scalable, and endlessly customizable. If you’re looking to consolidate your smart home devices or simply want a more robust ecosystem, I highly recommend giving Hubitat a try. The learning curve is minimal, and the payoff is well worth it!Happy automating! ![]()
