I’ve been exploring the integration of my Nuki smart lock with Google Home, and I wanted to share my experience and some tips for anyone looking to do the same. Here’s how I made it work seamlessly!### The GoalI wanted to control my Nuki lock using Google Assistant without needing the Nuki app. Specifically, I wanted to unlock the door without opening it, which was a bit tricky at first.### The ChallengeInitially, I noticed that when I said, “Hey Google, unlock the front door,” the lock would open but the door itself would swing open. This wasn’t what I wanted—I just wanted the lock to unlock, not the door to open automatically.### The SolutionAfter some research, I discovered that Nuki supports both unlock and open actions. The key was to set up the right commands in Google Home. Here’s what I did:1. Pairing the Lock I started by adding my Nuki lock to Google Home through the Works with Google feature. This was straightforward—just a matter of following the setup guide.2. Customizing Commands To prevent the door from opening automatically, I needed to ensure Google Assistant used the unlock command instead of open. I did this by explicitly training Google Assistant: plaintext Hey Google, unlock the front door Over time, this trained the system to use the unlock action.3. Testing Different Scenarios I tested various voice commands to see how the lock responded: - “Unlock the front door” worked perfectly—it just unlocked without opening. - “Open the front door” still resulted in the door opening, which I avoided once I knew the difference.### The ResultNow, I can seamlessly unlock my door using Google Assistant without any unwanted door movements. It’s incredibly convenient, especially when I’m juggling groceries or packages.### Tips for Others- Experiment with Commands: Try different phrasings to see how your lock responds.- Use Custom Routines: Combine unlocking with other actions, like turning on lights, for a fully integrated smart home experience.- Check for Firmware Updates: Ensure your Nuki lock is up to date for the best compatibility.If you’re looking to integrate your Nuki lock with Google Home, I hope this helps! Let me know if you have any questions or tips of your own—I’d love to hear how others are making this work.
