Successfully Integrating Nuki Lock with HomeKit: A Step-by-Step Guide
After spending hours researching and troubleshooting, I finally managed to integrate my Nuki Lock V3.0 with HomeKit without needing a bridge! Here’s how I did it, in case anyone else is struggling with the same issue.
First, I followed the video tutorial provided by simon42, which was incredibly helpful. I set up the HomeKit bridge in Home Assistant and included the Nuki lock entity in the configuration. Everything seemed to work smoothly in HA, but when I tried to add it to HomeKit, I didn’t receive the QR code prompt.
I realized the issue might be with how the entity was being passed through the bridge. After some digging, I found that defining the lock as a switch in the HomeKit configuration worked perfectly. While it’s a bit of a workaround, it allows me to control the lock seamlessly through HomeKit without any additional hardware.
Here’s the configuration I used:
yaml
port: 51827
mode: accessory
filter:
include_entities:
- switch.nuki_lock
I also want to thank the community for all the resources and support. It’s amazing how much time and frustration can be saved by tapping into this wealth of knowledge!
If anyone else is having trouble with HomeKit integrations, don’t hesitate to reach out. Let’s keep sharing tips and tricks to make our smart homes even smarter! :rocket:
