Successfully Integrating Nuki Opener with Terraneo 600WS
Hi everyone, I wanted to share my experience with integrating the Nuki Opener with my Terraneo 600WS. At first, I was a bit confused about the wiring setup since it seemed quite different from what I expected. I stumbled upon an old post suggesting connecting to position 6 instead of 5, and that made all the difference!
Here’s what I did:
  1. Connected the cable to position 6 as mentioned in the post.
  2. Assigned the colors to the terminals as follows:
    • Black and violet to terminal 3
    • Red to terminal 2
    • Orange to terminal 1
    • Green to terminal 5 (which I later realized was position 6)
    • Blue to T1
After setting everything up, I tested the opener and it worked perfectly! The door opened smoothly via the app, and the continuous mode issue I was facing earlier was resolved. I was worried about the bell not responding, but once everything was correctly connected, it worked without any hiccups.
This experience taught me the importance of checking forums for similar issues and not being afraid to try different solutions. If you’re facing similar challenges, don’t hesitate to reach out—I’m happy to help!
Cheers,
