Successfully Integrating Piper Text-to-Speech on OpenHAB
After a lot of trial and error, I finally managed to get the Piper Text-to-Speech add-on working on my OpenHAB setup! Here’s how I did it and some tips for anyone else who might be struggling with the same issue.
First, I installed the Piper add-on through the OpenHAB Paper UI. Since my system is offline, I had to manually download the add-on and place it in the correct directory. I also made sure to copy the necessary JAR files and voice model into the userdata/piper folder. Debugging was a bit tricky, but enabling debug logging for the Piper add-on really helped me pinpoint where things were going wrong.
One thing I learned is the importance of file permissions. Make sure the OpenHAB user has read access to the voice model files. I also had to ensure that the Piper add-on was fully loaded before testing it, which I confirmed by checking the logs.
To test the setup, I created a simple rule that triggers a greeting at a specific time. Initially, I encountered the same error message about the add-on not being loaded, but after verifying all the paths and ensuring the add-on was correctly installed, everything started working smoothly.
Here are a few tips for others:
  • Double-check the file paths and ensure all necessary files are in place.
  • Use debug logging to get detailed information about what’s happening.
  • Test with a simple rule first before moving on to more complex automations.
It’s amazing how much more interactive my smart home feels with text-to-speech functionality. I’m already planning to integrate Piper into more rules, like announcing the weather in the morning or giving reminders throughout the day. If you’re looking to add a voice to your OpenHAB setup, Piper is definitely worth the effort!
Happy automating everyone! :rocket:
