Hello fellow智能家居 enthusiasts, I wanted to share my recent success in integrating PM5340 devices with a Rockwell ControlLogix PLC. Initially, I was facing a challenge in making the consumption data from PM5340 available for my PIMS server. After some research and experimentation, I found a reliable solution using Ethernet communication. Here’s how I did it:
Understanding the Communication Protocol: The PM5340 supports Modbus TCP/IP over Ethernet, which is perfect for integration with ControlLogix. I configured the PM5340 to use a static IP address on the same subnet as the ControlLogix PLC.
Setting Up the ControlLogix PLC: I used the Rockwell Software to create a new communication path in the ControlLogix PLC. This involved specifying the IP address of the PM5340 and setting the appropriate port for Modbus communication.
Configuring the Data Exchange: I programmed the ControlLogix to periodically poll the PM5340 for consumption data. This involved setting up a timer-based task that reads the necessary registers from the PM5340 and stores the data in the ControlLogix memory.
Testing and Validation: After setting up the communication, I tested the integration by monitoring the data flow between the PM5340 and the ControlLogix. I used the Rockwell tools to verify that the data was being read correctly and stored in the PLC.
Integration with PIMS: Once the data was reliably available in the ControlLogix, I configured the PIMS server to read the data from the PLC. This involved setting up a new data source in PIMS and mapping the data fields appropriately.
This integration has been a game-changer for my facility, providing real-time consumption data that helps optimize our operations. I hope this guide helps anyone else looking to integrate PM5340 devices with ControlLogix. Happy integrating! ![]()
