Hey everyone! I wanted to share my experience integrating the Seeedstudio ReSpeaker 4-Mic Array with Hassio. I come from the world of Mozilla-IoT and Mycroft, but I decided to give Hassio a try for its broader device support and active community.
The Challenge:
Adding the ReSpeaker wasn’t straightforward since Hassio doesn’t have a package manager or compiler out of the box. I had to figure out how to install the necessary drivers without SSH access or root privileges.
The Solution:
After some research, I discovered that compiling the driver on another system and transferring the binary to Hassio was the way to go. I also found a helpful guide on enabling SSH access to the host system, which made the process much easier.
The Outcome:
I managed to get the ReSpeaker working seamlessly with Hassio. Now, I can use voice commands like “Hey Ada” without needing a subscription to Home Assistant Cloud. It’s been a fantastic addition to my smart home setup!
Tips for Others:
- If you’re new to Hassio, start with simpler integrations before tackling custom hardware.
- Don’t hesitate to reach out to the community for help. The support I received was invaluable.
- Always back up your system before making significant changes.
This project has been a great learning experience, and I’m excited to see what other custom integrations I can achieve with Hassio!
