Hey everyone! I’ve been diving into the world of shell commands in HassOS and wanted to share my journey and some tips that might help others. ![]()
My Experience:
I recently tried setting up shell commands to automate some tasks, but I ran into a few bumps along the way. Initially, I wasn’t sure if shell commands were still supported in HassOS, especially after switching from a virtual environment. After some research, I discovered that while they are supported, the setup can be a bit tricky.
The Setup Process:
- File Structure: I created a
shell_scriptsfolder in my config directory. It took me a while to figure out the correct path, but/config/shell_scripts/worked perfectly. - Script Creation: I wrote a simple script to control an iKettle using
netcat. The script worked flawlessly when run directly in the terminal, but HassOS wasn’t triggering it as expected.
- Troubleshooting: I checked the permissions and realized the script needed execute permissions. Running
chmod +x /config/shell_scripts/ikettleon.shdid the trick! - Testing: I used the Developer Tools to test the service call manually. It was a relief when everything started working after that tweak.
Tips for Others:- Permissions: Always ensure your scripts have the correct execute permissions.- Paths: Double-check the file paths in your configuration. Even a small typo can cause issues.- Testing: Use the Developer Tools to manually trigger your scripts. It’s a great way to troubleshoot without waiting for automation triggers.Closing Thoughts:
Shell commands in HassOS are a powerful tool once you get the hang of them. They allow for a lot of customization and can integrate with almost any device. If you’re hesitant to dive in, I encourage you to give it a try! ![]()
Have you successfully used shell commands in HassOS? I’d love to hear your experiences and any tips you might have! Let’s keep the discussion going! ![]()
