Successfully Integrating Shelly 2 PM with HomeyPro: A Step-by-Step Guide
Hey everyone! I thought I’d share my experience with integrating the Shelly 2 PM into my HomeyPro setup. At first, I was a bit puzzled when the device showed up in the Shelly app but not in HomeyPro. After a bit of research and some trial and error, I figured it out! Here’s how I did it:
  1. Firmware Check: Ensure both your Shelly device and HomeyPro are running the latest firmware. Compatibility issues can often be resolved with an update.
  2. Device Addition: Go to the HomeyPro app, navigate to the devices section, and select ‘Add Device.’ Choose the appropriate category for your Shelly 2 PM.
  3. Discovery Mode: Enable discovery mode in HomeyPro. This helps the hub detect new devices on your network.
  4. Shelly Integration: Open the Shelly app, go to settings, and ensure that HomeyPro is listed as an allowed integration. If not, add it manually.
  5. Pairing: Follow the prompts in HomeyPro to pair the Shelly 2 PM. This might involve pressing a button on the device or using a QR code.
  6. Configuration: Once paired, configure the device settings in HomeyPro to match your preferences. I set mine up to control my roller blinds seamlessly!
This process was a bit nerve-wracking at first, but the satisfaction of getting everything connected was worth it. If anyone else is struggling with similar issues, feel free to reach out—I’d be happy to help!
Cheers,
