Recently, I faced an issue where my Shelly devices were frequently becoming unavailable in Home Assistant. After some troubleshooting, I discovered that the problem was related to the Wi-Fi network configuration and the firmware version of the devices. Here’s how I resolved it and successfully integrated my Shelly devices:
Wi-Fi Network Stability: I realized that the Shelly devices connected through my Fritzbox repeaters were experiencing signal instability. By adjusting the Wi-Fi channel settings on my Fritzbox 7590 and ensuring a strong, stable connection, I significantly reduced the dropout issues.
Firmware Updates: I checked the firmware versions of my Shelly devices and updated them to the latest stable release. This update not only improved the device performance but also resolved some connectivity issues that were causing the devices to become unresponsive.
Configuration Adjustments: I reviewed the integration settings in Home Assistant and ensured that all devices were correctly paired and configured. Disabling the AP mode on the Shelly devices also helped in maintaining a consistent connection.
Testing and Automation: After resolving the connectivity issues, I set up some basic automations to test the reliability of the devices. For instance, I configured my Shelly Dimmer 2 to turn on the hallway lights when the front door is opened. It worked seamlessly!
This experience taught me the importance of checking both hardware and software configurations when integrating smart devices. By addressing the root causes and systematically troubleshooting, I was able to create a more reliable and efficient smart home setup.
If anyone is facing similar issues, I highly recommend checking your network settings, ensuring all firmware is up to date, and verifying the integration configuration in Home Assistant. Happy automating! ![]()
