I recently embarked on a project to integrate my Shelly devices with my Hörmann door system, and I must say, it was a rewarding experience!
I wanted to share my journey in case anyone else is considering a similar setup or facing challenges along the way.
The Challenge:
I had a Hörmann SupraMatic 4 door system and wanted to automate it using my Shelly 2.5 devices. The goal was to control the door opener, track its status, and even manage external lighting—all through my smart home setup. Initially, I faced some hurdles, especially with the UAP1 module and its compatibility with Shelly’s automation capabilities.
The Solution:
After some research and trial and error, I discovered that using the Hörmann UAP1 HCP module was the key. This module provided the necessary interfaces to integrate seamlessly with Shelly. I also added a Shelly 2.5 to handle the automation logic, such as detecting when the door was open for too long and sending alerts via my smart home system.
Key Steps:
- Installation: I mounted the UAP1 module and connected it to my Shelly 2.5. This allowed me to monitor the door’s status and control its operation.
- Automation Logic: Using Shelly’s rules engine, I set up scenarios like automatically turning on the garage lights when the door opened and sending notifications if the door remained open beyond a set time.
- Testing: I thoroughly tested each function to ensure reliability. It was a bit nerve-wracking at first, but seeing everything work perfectly made it all worthwhile!
Tips for Others:
- Documentation: Make sure to thoroughly read through the manuals for both your Shelly devices and Hörmann system. Understanding their capabilities and limitations is crucial.
- Start Small: Begin with basic automations and gradually add more complex features as you become comfortable.
- Community Support: Don’t hesitate to reach out to forums or communities if you hit a roadblock. There’s a wealth of knowledge and helpful tips out there!
Conclusion:
Integrating Shelly devices with my Hörmann door system has transformed my garage into a smart, efficient space. It’s been a fantastic way to enhance my home automation setup, and I’m excited to explore even more possibilities in the future! If anyone has questions or needs advice, feel free to ask—I’m happy to help! ![]()
