I recently faced a challenge when trying to connect my Shelly devices with the SMA Home Manager 2.0 for my solar energy system. Initially, I was concerned that the integration might require complex workarounds or additional hardware, but I’m thrilled to share that I found a straightforward solution!
After some research, I discovered that the Shelly PLUS 1 can seamlessly communicate with the SMA Home Manager without needing a Raspberry Pi or other intermediaries. The key was ensuring both devices were on the same local network. Once connected, I could easily control my devices through the SMA interface, which simplified my energy management流程.
For anyone looking to integrate Shelly devices with SMA, here’s a quick tip: make sure your Shelly device is discoverable on your LAN and that the SMA Home Manager is updated to the latest firmware. This setup not only enhances efficiency but also adds a layer of convenience to monitoring and controlling your energy usage.
It’s amazing how modern smart home technologies can work together to create a more sustainable and efficient living environment. Kudos to both Shelly and SMA for their compatible solutions! ![]()
