Successfully Integrating Shelly Pro EM3 with OpenHAB
I wanted to share my experience with integrating the Shelly Pro EM3 energy monitor with OpenHAB. Initially, I faced some challenges with the Shelly binding, as the device would disconnect frequently and the state refresh wasn’t reliable. After some research and troubleshooting, I decided to try an MQTT integration as an alternative solution.
Here’s what I did:
  1. MQTT Setup: I configured my MQTT broker to handle the Shelly Pro EM3’s data. The device reliably sends updates over MQTT, which proved to be more stable than the HTTP API.
  2. Rule Configuration: I created a rule in OpenHAB to handle the MQTT messages and update the relevant items. This allowed me to monitor real-time power consumption and set up alerts for specific thresholds.
  3. Testing and Optimization: I tested the setup extensively to ensure that the data was being captured accurately and in real-time. I also adjusted the MQTT topics to match the device’s output for seamless integration.
The result? A stable and reliable energy monitoring system that provides the real-time data I need. This setup has been running smoothly for several weeks now, and I’m thrilled with the results.
If anyone else is struggling with the Shelly binding, I highly recommend exploring MQTT integration as a robust alternative. It might require a bit more setup, but the payoff in terms of reliability is well worth it. Happy automating! :rocket:
