Recently, I successfully integrated my Slimmelezer+ device with the Aidon 6534 energy meter, which follows the Swedish Branschrekommendation 1.2 standard. This process was initially quite challenging, but I managed to find a solution through research and some trial and error. Here’s a detailed breakdown of how I did it, in case anyone else is facing similar issues.
The Challenge
Slimmelezer+ is a fantastic device for reading energy meter data, but out of the box, it doesn’t support the specific HDLC-based communication protocol used by the Aidon 6534 meter. After some extensive online research, I stumbled upon a forum where a user had already solved this problem using a modified version of Forsberg’s ESPHome P1 reader code. This was a game-changer!
The Solution
Hardware Setup
- Connect the Slimmelezer+ to your computer using a USB-C cable.
- Ensure the device is powered via the P1 port for optimal performance.
Software Configuration
- Install the ESPHome integration in Home Assistant.
- Create a new device named
p1readerand skip the initial setup steps. - Replace the default configuration with the modified
p1reader.yamlfile from Forsberg’s GitHub repository.
Secrets Configuration
- Set up your Wi-Fi credentials and other necessary passwords in the ESPHome secrets file.
Firmware Installation
- Connect the Slimmelezer+ to your computer and install the modified firmware using the ESPHome interface.
- Add the
p1readerdevice to Home Assistant by searching for it under the ESPHome integration. - Configure the necessary ports and API passwords as outlined in the setup guide.
- Add the
Testing and Verification
After installing the firmware and integrating the device, I monitored the data flow to ensure everything was working correctly. The Slimmelezer+ began capturing data from the Aidon meter seamlessly, and I could view the information within Home Assistant. This was a huge relief after the initial setup challenges!
Tips for Success
- Backup Your Work: Always keep a backup of your configuration files and settings. This can save you a lot of time if something goes wrong during the setup process.
- Community Resources: Don’t hesitate to reach out to forums and communities for help. The smart home community is incredibly supportive, and chances are someone else has encountered and solved the same issue.
- Documentation: Keep detailed notes of each step you take during the setup process. This will be invaluable if you need to troubleshoot issues later on.
Conclusion
Integrating the Slimmelezer+ with the Aidon 6534 meter was a rewarding experience, despite the initial hurdles. By leveraging community resources and modifying existing code, I was able to create a functional and efficient energy monitoring setup. If you’re facing similar challenges, I hope this guide helps you achieve the same success!
Happy tinkering! ![]()
