I’ve been on a journey to integrate my smart lighting system using ESPHome, and I wanted to share my experiences and some tips for anyone looking to do the same. ![]()
My Setup
I have a mix of RGBIC and CCTIC led strips from LSC, which I’ve been trying to control locally without relying on the cloud. The goal was to have precise control over each segment and avoid the lag that comes with cloud-based solutions.
The Challenges
Initially, I faced some hurdles with the firmware. The device was running a patched Tuya firmware, which made flashing it directly impossible. After some research, I found that using the BK7231 GUI Flash Tool was the way to go. I backed up the original firmware just in case and successfully flashed OpenBeken onto the device. This was a big milestone! ![]()
Configuring ESPHome
Once the device was flashed, I set up ESPHome with the beken_spi_led_strip platform. I had to experiment with the rgb_order setting and the chipset to get the colors right. I also discovered that the white LEDs (Cool White and Warm White) were addressed on odd-numbered segments, while the RGB LEDs were on even segments. This was a bit tricky but manageable with some trial and error.
Tips for Others
- Backup First: Always make a backup of your device’s current firmware before attempting any flashing. It’s a simple step that can save you a lot of headaches.
- Understand the Pinout: Take the time to understand the pinout of your device. In my case, activating pin P8 was crucial for powering the LED strip.
- Use Partitions: ESPHome’s
light.partitionfeature is incredibly useful for controlling different segments of your led strip. I set up partitions for RGB and white LEDs separately, which made it easier to adjust colors and brightness without affecting the entire strip. - Community Support: Don’t hesitate to reach out to the community for help. Forums like Elektroda and GitHub discussions were invaluable resources for me.
Looking Ahead
I’m really excited about the possibilities with ESPHome. I plan to explore more advanced features like creating custom effects and integrating voice control. If anyone has tips or suggestions, I’d love to hear them! ![]()
Happy integrating! ![]()
