I wanted to share my experience with using smart plugs for monitoring the energy consumption of my household appliances. After experimenting with several devices, I found that using smart plugs with energy monitoring capabilities has been a game-changer for optimizing my home automation setup.
One of the main challenges I faced was accurately determining the start and stop times of devices like my dryer and washing machine. Initially, I struggled with balancing timely notifications and avoiding false positives due to varying energy profiles of different programs. However, I discovered a reliable solution by creating two separate flows: one to detect when a device starts and another to detect when it stops.
Here’s how I set it up:
Device Start Flow: This flow triggers when the energy usage of a device exceeds a predefined threshold, indicating that the device has started. Once detected, this flow disables itself to prevent false notifications.
Device Stop Flow: This flow monitors the energy usage and triggers when the device’s power consumption drops below a certain threshold, indicating that the device has stopped. At the end of this flow, it re-enables the start flow for the next cycle.
This setup has significantly reduced false alarms and provided accurate monitoring of my appliances. I’ve been able to track energy usage patterns and even optimize my laundry schedule to off-peak hours!
If anyone is looking to implement a similar system, I’d recommend starting with a single device to fine-tune the energy thresholds before expanding to other appliances. It’s a fantastic way to gain insights into your energy consumption while maintaining a seamless automation experience.
I’d love to hear if others have tried similar approaches or have tips for improving energy monitoring setups!
