Successfully Integrating SmartThings Devices After Update
Hi everyone, I wanted to share my recent experience after updating my Home Assistant installation. I upgraded from version 103.4 to 104.1 and encountered some issues with my SmartThings devices. Initially, all my devices became unavailable, which was quite concerning. However, I managed to resolve the issue by reverting to a previous snapshot and then carefully updating again. Here’s how I did it:
  1. Identify the Issue: After the update, I noticed that my SmartThings devices were offline. I checked the logs and found some connection errors, which indicated a potential compatibility issue post-update.
  2. Revert to Snapshot: I decided to use a snapshot from before the update to restore my system. This brought everything back to version 103.4, and thankfully, my SmartThings devices were back online.
  3. Gradual Update: Instead of updating directly to 104.1, I did it in smaller steps to monitor any issues. This approach helped me identify the exact point where the devices went offline again.
  4. Reconfiguration: I found that some integrations needed reconfiguration after the update. I manually reconnected each device and ensured that all credentials were up to date.
  5. Testing: After reconfiguring, I tested each device to make sure they were functioning correctly. It was a bit time-consuming, but it paid off in the end.
I wanted to share this experience because it highlights the importance of regular backups and the value of patience when troubleshooting. If anyone else is facing similar issues, I hope this helps! :rocket:
