After some trial and error, I managed to integrate my SmartThings Water Leak Sensors (STS-WTR-250) with Hubitat! Here’s how I did it and what I learned along the way.
The Challenge
I have several SmartThings Water Leak Sensors placed under sinks and toilets. When I decided to switch to Hubitat, I was worried about losing these crucial sensors. Resetting them didn’t help initially—they wouldn’t show up during device discovery.
The Solution
After some research and troubleshooting, I found that the key was to ensure the sensors were in pairing mode while Hubitat was scanning for new devices. Here’s a step-by-step guide that worked for me:
- Reset the Sensor: Press and hold the sensor’s button until the LED starts flashing.
- Open Hubitat: Go to the Hubitat app and navigate to the device discovery section.
- Pair the Sensor: While Hubitat is scanning, press and hold the sensor’s button again until you see a confirmation on the Hubitat app.
- Assign to Room: Once paired, assign the sensor to the appropriate room for easier management.
Tips for Success
- Timing is Everything: Make sure the sensor is in pairing mode exactly when Hubitat starts scanning.
- Check Signal Strength: Ensure there’s no interference between the sensor and the Hubitat hub.
- Be Patient: Sometimes it takes a few attempts, but persistence pays off!
Why This Matters
Having these water leak sensors integrated into Hubitat gives me peace of mind. I can now monitor my home’s water safety alongside all my other smart devices in one seamless ecosystem. Plus, it’s satisfying to repurpose existing hardware instead of buying new sensors!
If anyone else is struggling with similar integrations, feel free to reach out—I’d be happy to help! ![]()
