I’ve been on a journey to integrate my Smobot grill temperature device with my Home Assistant setup, and I’m thrilled to share my success! ![]()
Initially, I was a bit hesitant about how seamless the integration would be. After some research and tinkering, I discovered that using MQTT as a bridge was the key. By configuring the Smobot to publish temperature readings to MQTT topics, I could easily pull this data into Home Assistant.
Here’s a quick breakdown of what I did:
- Setup MQTT Broker: I installed Mosquitto on my Raspberry Pi to act as the MQTT broker.
- Configure Smobot: I followed the manufacturer’s guide to set up MQTT publishing on my Smobot.
- Integrate with HA: I added a new MQTT sensor in Home Assistant to subscribe to the Smobot’s temperature topic.
Now, I can monitor my grill’s temperature right from my phone or the web interface! It’s incredible how this integration has taken my backyard setup to the next level. ![]()
If anyone else is looking to do something similar, I’d be happy to share more details or troubleshoot any issues you might encounter. Let’s keep the smart home magic alive! ![]()
