I’m thrilled to share my recent success in integrating my SMA solar inverter data into my smart home ecosystem using Node-RED. After some trial and error, I managed to read the inverter’s data and create custom sensors for monitoring. Here’s how I did it and what I learned along the way!—### My Setup and GoalsI wanted to track the DC power from two strings of my solar panels and display this data in my energy dashboard. The goal was to create two sensors with the following attributes:- State Class: Measurement- Unit of Measurement: Watts (W)- Device Class: PowerAdditionally, I wanted to calculate the total energy generated by both strings over time. This would allow me to see the cumulative contribution of each string to our energy production.—### The Process1. Reading the Inverter Data: I started by using Node-RED to read the payload from my SMA solar inverter. The payload included values like DC power string 1, DC power string 2, and other metrics like AC power and frequency.2. Creating Sensors: I configured Node-RED to extract the DC power values and create two separate sensors. Each sensor was set up with the attributes mentioned above to ensure compatibility with my energy dashboard.3. Calculating Total Energy: To track the cumulative energy, I implemented a state_class: total_increasing for both sensors. This allows me to monitor the total energy generated by each string over time.4. Testing and Validation: I tested the setup by monitoring the sensors in real-time. It was exciting to see the data updating as the sun moved across the sky and the panels generated more power.—### Challenges and Solutions- Data Parsing: Initially, I struggled with correctly parsing the payload to extract the DC power values. Using debug nodes in Node-RED helped me understand the structure of the data and identify the correct paths.- Sensor Configuration: Ensuring that the sensors were properly configured with the right attributes was crucial for their integration into my energy dashboard. I referenced the Home Assistant documentation to make sure everything was set up correctly.—### Tips for Others- Start Small: Begin by reading and logging the data before attempting to create sensors. This helps you understand the structure and verify that everything is working as expected.- Use Debug Nodes: They are invaluable for troubleshooting and understanding your data flow.- Leverage Documentation: Both Node-RED and Home Assistant have excellent documentation that can guide you through the setup process.—### Next StepsNow that I have the solar data integrated, I’m looking to expand this setup by:- Adding alerts for low power output or unusual readings.- Creating a dashboard that compares daily, weekly, and monthly energy production.- Exploring the possibility of using this data to optimize energy usage in my home.—If anyone has questions or needs help with similar projects, feel free to reach out! I’d be happy to share more details or troubleshoot issues together. ![]()
