Successfully Integrating Sonoff Mini into SmartThings
Hi everyone, I wanted to share my experience integrating the Sonoff Mini into my SmartThings setup. Initially, I was a bit overwhelmed because I couldn’t find a straightforward guide for my specific setup. However, after some research and trial and error, I managed to get everything working smoothly. Here’s how I did it:First, I downloaded the SmartThings app and made sure my hub was properly connected. I then looked for the Sonoff Mini in the SmartThings app, but it wasn’t automatically detected. I realized I needed to add it manually. I found a simple guide online that explained how to connect the Sonoff Mini using the SmartThings app. The process involved searching for the device, entering the correct Wi-Fi credentials, and pairing it with the hub.Once paired, I tested the device to ensure it was responding to commands. I was thrilled when it worked perfectly! I then decided to take it a step further by setting up some basic automation rules. For instance, I programmed the Sonoff Mini to turn on my outdoor lights at sunset and turn them off at midnight. It’s been working like a charm ever since.I also discovered that the Sonoff Mini is compatible with Alexa, which allows me to control my lights using voice commands. This integration added a whole new level of convenience to my smart home setup.Overall, this experience taught me that even if something seems complicated at first, with patience and persistence, it’s possible to achieve great results. I hope my experience can help others who are looking to integrate the Sonoff Mini into their SmartThings ecosystem.Happy automating everyone! :slight_smile:
