I recently faced an issue where my Sonos favorites and playlists weren’t showing up in the Home Assistant flow cards after updating the Sonos app to version 6.1.1. After some research and troubleshooting, I managed to resolve the problem and thought I’d share my experience in case others are facing similar issues.
First, I checked if the integration between Sonos and Home Assistant was correctly set up. I ensured that all my Sonos devices were properly paired and recognized within Home Assistant. If you’re encountering the same issue, I recommend verifying the integration settings in the Home Assistant configuration.
Next, I looked into the flow cards to see if there were any errors or logs that could provide more insight. I discovered that the issue might be related to how the Sonos app handles favorites and playlists post-update. To resolve this, I reauthenticated my Sonos devices within Home Assistant, which involved unlinking and relinking them.
After reauthenticating, I tested the flow cards again and was delighted to see that my favorites and playlists were now visible and functional. This update not only fixed the issue but also improved the overall integration experience.
If you’re still experiencing difficulties, I suggest checking the Home Assistant community forums for the latest updates or potential workarounds. Additionally, ensuring that both the Sonos app and Home Assistant are running on the latest versions can help prevent similar issues in the future.
It’s always reassuring to know that the community is active and supportive. If anyone else has encountered this problem or has tips on maintaining seamless integration, I’d love to hear your experiences!
Happy automating!
