Successfully Integrating Spotify with Google Home in Home Assistant
Hey everyone! I wanted to share my recent success in getting Spotify to work seamlessly with my Google Home devices through Home Assistant. It was a bit of a journey, but I’m thrilled with how it turned out!
Initially, I was a bit puzzled about how to set this up. I knew I had the Spotify integration in Home Assistant working, but casting to Google Home wasn’t straightforward. I stumbled upon the Media Control Card Configuration, which seemed promising. I configured it with my Spotify entity, and while it showed my current track, selecting a device to cast to wasn’t obvious.
After some digging through the forums and documentation, I realized I needed to ensure that the Google Home devices were properly integrated into Home Assistant. Once that was sorted, I could use the media player controls within Home Assistant to select the desired Google Home device. It was a bit of a workaround, but it worked!
Here’s a quick breakdown of what I did:
  1. Spotify Integration: Made sure Spotify was properly set up in Home Assistant.
  2. Google Home Integration: Ensured all my Google Home devices were recognized by Home Assistant.
  3. Automation Setup: Created a simple automation that triggers when I say, “Hey Google, play Spotify on [device name].”
  4. Testing: Tested extensively to ensure the casting works smoothly, even across different rooms.
The best part? Now I can control my Spotify playlists directly from my Google Home devices, perfect for setting the mood in any room without lifting a finger. It’s a small victory, but it makes a big difference in my daily routine!
I’d love to hear how others have integrated their Spotify with Google Home. Any tips or alternative methods are always welcome! :notes::house:
