I recently had an interesting experience integrating my Tasmota devices with Home Assistant. It started when I noticed that several of my Tasmota devices were not being recognized correctly by TasmoAdmin. The IP addresses listed were incorrect, even though the devices worked perfectly within Home Assistant. This was puzzling, especially since I had just reset my router, which changed all the DHCP addresses.After some research, I discovered that TasmoAdmin might not be rescanning my network automatically. I decided to try adding each device manually, which worked, but it was time-consuming. I then explored the possibility of forcing TasmoAdmin to rescan my network. After some digging, I found that there is indeed a way to do this, which saved me a lot of time and frustration.This experience taught me the importance of understanding how different platforms interact within a Home Assistant setup. It also highlighted the value of community forums, where I found the solution to my problem. If anyone else is having similar issues, I recommend checking the network scanning settings in TasmoAdmin and ensuring that all devices have static IP addresses to avoid future problems.It’s amazing how integrating various smart devices can transform your home, but it does require some patience and troubleshooting. I’m excited to continue expanding my setup and exploring new possibilities with Home Assistant!
